Jackie_Treehorn
Mar 14, 2016Explorer
Old-Biscuit wrote:
Find the battery pos cable...find the in-line fuse or DC circuit breaker on that pos cable (usually close to battery). It has blown or tripped (DC circuit breaker is a small box with 2 studs---most are auto resetting/some have a very small tab on side that has to be pushed to reset)
Until you find/fix that 'protective device' NO DC charge from converter to battery
There is a DC Circuit Breaker box above my kitchen counter. The breakers there all appear to be fine. I'll try to track that line leaving the converter which goes up under one of my basement compartments and then connects to the battery array under my front door steps. Somewhere in the middle there could be a fuse or breaker and if that's the case that's a likely resolution. Maybe my starting point there is to request a wiring diagram from Winnebago for my model which should answer the breaker/fuse question. Thanks for your help.
