Jackie_Treehorn
Mar 14, 2016Explorer
AllegroD wrote:
The breaker is probably nearer the batteries. Often in the section beside or behind the battery box. Did you remove the cables from the batteries and test voltage to the end of the cables that attach to the batteries? If full charge is getting to the end of the cables, you may have a dead cell in the batteries.
With the generator off there is still a voltage reading of 11.4 volts at the battery, which will be the battery charge voltage.
