Dale_Traveling
Mar 14, 2016Explorer II
Jackie Treehorn wrote:Not really. As long as there's enough power to activate the solenoid pressing the switch on the dash will tie the house and chassis batteries together. Switch is spring loaded so as soon as you let go the circuit opens.
Thanks a lot Dale. I haven't used the Aux Start before. Is there any protocol for that? Keys in the ignition in aux, etc.?
One other thing to try is with the coach quiet cycle the AUX Battery Disconnect switch near the door. With the coach quiet you can sometimes hear the solenoid activating which will at least let you know that part of it is working.
