Gazelle05 wrote:
Problem solved---after going back over disconnecting the salesman cut off switch solenoid I found a third wire that needed to be included in the two that I had connected. Everything is working (everything). Thank all of you for your help. What a great resourse to be able to fall back on when things go bad. Safe Travels
Thanks for getting back to everyone - always nice to know when we find out what the solution actually was.
Trust me the reason most of us Know about the issue is because we have Had the ISSUE.
Thanks,
