- chuckftboyExplorerCould be a connection in the steering column. thats the only thing that is common to all three if the wipers are on the turn signal arm. Look for a pinched or broken wire.
- midnightsadieExplorer IIsome times fuse holders get a little oxidation on them and the fuse itself clean them up a bit, I,ve used a contact clean and it worked ,but a bit of steel wool is better watch that you only touch one side at a time of the fuse mount.
38,766 PostsLatest Activity: Jan 10, 2026
