STBRetired
Mar 08, 2020Explorer
Try taking the transmission out of overdrive (D with circle) and see if drone still happens at same speed. Downshifting to D uses different gearing in transmission. If drone still the same, then is not transmission, but most likely u-joint or rear differential. If drone is gone, or now happens at different speeds, then suspect transmission.
