ItsyRV
Mar 09, 2020Explorer
Assuming you have the GM 4L80 tranny (first gen), there are no known issues you mentioned. That means it may not be the transmission at all or it's a unexpected problem. The closest I could find to any related type issue, but not as you describe is from a filter issue where it's sucking up to the underside causing a vibration when in OD. This is fixed by installing a new filter (and connector) that isn't fatigued from age.
Now, even if it's a internal transmission issue, new parts are widely available as are techs to do the work. Heck, it could be cheaper at times to have a new or remanufactured 2nd gen 4L80E installed. But, odds are it;s not actually the transmission.
