Bird_Freak
Mar 09, 2020Explorer II
jehuty wrote:New ring gear and pinion. This is a common problem in truck rear ends if the gears were not set up correctly or do not wear in correctly when breaking in.Bird Freak wrote:
Pinion gear in rear end if noise goes away when letting off gas. Sound will travel thru driveshaft.
Been there.
Really? Have you done anything to it?
