jehuty
Mar 10, 2020Explorer
Bird Freak wrote:jehuty wrote:New ring gear and pinion. This is a common problem in truck rear ends if the gears were not set up correctly or do not wear in correctly when breaking in.Bird Freak wrote:
Pinion gear in rear end if noise goes away when letting off gas. Sound will travel thru driveshaft.
Been there.
Really? Have you done anything to it?
Interesting, didn't know there were a break in procedure for the rear end.
If From incorrect seating, sounds like it can be fixed by readjusting with shims?
When you replaced the ring and pinion, did you kept the same gearing?
Can You also throw us a link of where you purchased?
Would like to do more research about this if there's any mechanical adverse effects left alone or ignored for x amount of miles
