danddclydes's avatar
danddclydes
Low batteries
Ok - I admit it, the weather and general laziness has left me with batteries not strong enough to start my motorhome. It has been extremely cold!!! Now what do I do to jump it or somehow charge the batteries enough to start it? I am new to this and know I sound clueless.
Thanks for any help!
__________________________________________________________________
DandDClydes - 2014 Newmar Ventana LE 3845 - Pennsylvania arctic
  • If the house batteries have a good charge, hold your boost switch on for a minute or so and then try to start the engine.
    Or, you could run a jumper cable from the house battery positive connecter to the chassis battery positive connector to jump start the engine.
    Either way you are doing the same thing.
  • generator on my 02 Fleetwood gets it's juice from the coach battery . . . . I think.
    Many Class A's have a push switch on the dash connecting coach and chassis batteries together. That jump started mine for a month while I shopped around for a new chassis battery.
    If you're going to be wheels up for month+ you might invest in a battery tender. Make sure what you get says it will MAINTAIN a battery. It doesn't have to be big to maintain. Battery Tender is a brand that made these pretty popular.
    I'm not sure FLOAT and MAINTAIN are the same thing.
    Best,
    - bob
  • I can I believe. Does the start battery for the coach also start the generator?
