Mortdd wrote:
What happens when your RV place can't find the issue after hours of looking? High beams work, low beams do not. The high/low beam switch has been checked, the lights have been checked by a direct connect and they work etc.
your at the wrong repair shop. Both low beams out and bulbs are good it should be very easy to trace that out very easy
the first thing once the bulbs or seal beams are confirmed good is check the Fuses!! lots of A motor homes are fused then if there good pull the main switch and check for power in/power out and and so on
