donfrump
Dec 31, 2015Explorer
gbopp wrote:
How does the transmission fluid look? Dirty, burnt, is the level correct?
That's where I would start.
incorrect fluid level wont cause no first gear if it was that low it would have no gear. Those electronic overdrives are a complicated trans I would seek out a person whom knows that particular trans and let him repair it.I use to work on those a bit sounds like the low/reverse band may be burnt out
just remembered something else! does it seem to stay in 2 nd gear?
sometimes when there a engine problem the check engine lite comes on and they go into whats called limp home mode 2nd gear only
