outofplace
Dec 31, 2015Explorer
Well since its chevy powered it probably has a 4L80 in it and it could be as simple as the electronic board on the transmission thats not telling the transmission to go into Low gear. You say you can drive it,how does reverse gear work?..I believe this tranny is similar to the TH400 and 1st and reverse are the same drive drum so if reverse is working fine it might just be a Electronic issue or a simple flush. See if the fluid is dirty red or clear. If a dirty red may be a bigger issue
