Gjac
Feb 01, 2016Explorer III
wolfe10 wrote:This is what I do also. I dip a white paper towel in clean trans fluid and keep checking the fluid coming out until it looks like the clean stuff on the paper towel. The first time I did this (30k miles)I was shocked at the stuff in the bottom of the pan and on the magnet. At 60 k miles there was still stuff on the magnet but a lot less. At 90 k was about the same as 60 k. So if you have more than 30 k miles and have climbed a few long hills and got into the red (or the PO did) a fluid chg could help your shifting problem.
There are view points on both sides of the "flush" discussion.
I know in writing, Allison recommends AGAINST flushing. On cars/light trucks, I often dropped the pan, changed filter if present and filled. Then took loose the return line from cooler and idled engine until clean fluid came out.
Lots of ways to do it with good reasoning behind each.
