Wes_Tausend
Feb 02, 2016Explorer
allbrandauto wrote:
you are doing the same thing a flush machine does that's why they should call it a exchange machine if your not putting chemicals in trans. before you do it all your doing is exchanging all the fluid
I assume you are dropping the pan and changing the all-important filter within the standard service/charge then? In other words, are you saying you are price competitive with professional transmission repair shops that always drop the pan, absolutely change the filter, but usually don't bother pumping the converter if the prior tranny oil is in anywhere near normal condition? Yes, some serviceable old oil remains in this case. Some torque converters have drain plugs and are manually drained sans machine. All legitimate pro-shops do flush or replace the entire converter after a major failure, and I am a big believer in replacement, especially on lock-up units.
One should keep in mind that some trannies have been so neglected that the filter is so plugged with wear debris, it is thee primary source of shift problems. In other words, in this case, one could foolishly put the old oil back in, yet just adding the new filter would temporarily solve shift issues. The old '80's Chrysler Minivans were notorious for plugged filter problems. Of course it always made sense to replace the old oil at the same time. After such service, I always recommended that the owner definately mind the next recommended service interval, or no more than 40k miles... if they were not towing... and some were.
It is the strangest thing that many people that will give their autos reasonable engine oil changes, yet do not follow recommended service intervals for transmission fluid, or 3-year green coolant changeouts (5-years, orange Dex-Cool or extended life). Pertaining to coolant changeouts, many engines have needlessly corroded to an interior leak that allows coolant into the crankcase and destroys the otherwise well-oiled engine. And if the coolant interval is followed, there is again no compelling reason to remove all traces of the original coolant. If one wants to save $, partially draining and adding a new major portion is acceptable to save unnecessary labor and far superior to nothing.
And then there often a neglected need for new brake fluid, differential and transfer case refill under some conditions.
Wes
