revump's avatar
revump
Low Hot Water Pressure
I have an 06 Alfa See Ya. In Quartzsite, I tried to get one more day before filling up with fresh water but I let the pump start sputtering. Now, I have very low hot water pressure. It seems to be okay when I have shore water ... any ideas?
  • I am now
    tropical36 wrote:
    revump wrote:
    The cold side had good pressure ... found a faucet and put shore power to the water system ... must have had an air pocket somewhere ... cleared the system out and we have great pressure on both hot and cold sides now ... learn not to let the tank get so low
    And you're satisfied with the pump pressure (no outside connection) when on the tank for both C and H as well, correct?
  • Sometimes it's something really simple. Check the screen on the pump for sediment/hard water deposits. (Aerators at the faucets too) Hope it's an easy fix for more enjoyment.
  • The cold side had good pressure ... found a faucet and put shore power to the water system ... must have had an air pocket somewhere ... cleared the system out and we have great pressure on both hot and cold sides now ... learn not to let the tank get so low
  • tank empty?? pump sputtering sounds like no water to draw... how is the cold water side???
    Pump maybe has lost it's prime or sucking air. Try disassembly, cleaning, some silicone on the surfaces and then tighten everything evenly and well upon re-assembly.
