sullivanclan's avatar
sullivanclan
Low Mileage, Still Change the Oil?
We have a Jayco on the Ford 450, I put less than a 1000 miles on the last oil change five months ago. Geeze, maybe a dumb question, but with such low miles do I still need an oil change before our long trip this month?
  • Better to change it in the fall or the spring?
    I see Briggs & Stratten recommend fall for the lawn mower. A mechanic friend told me he had seen some bad pitting on hard metal engine surfaces after the vehicle had sat for a long time with dirty oil.
    Briggs & Stratten
  • Thanks everyone, very good information and you have eased my mind. Heading from Colorado to California next week.
  • mgirardo wrote:
    tatest wrote:
    With today's 5000 mile interval recommendations (Ford's schedule for Ford spec semisynthetic)
    Since at least 2008, Ford recommends every 7,500 miles or every 6 months.
    We haven't put 7,500 miles on the motorhome a year for several years now, so I change the oil at the beginning of every year.
    -Michael
    This is exactly what I do and matter of fact, I did it yesterday getting ready for a trip next week. I change it before the first trip each year. I had only 386 miles on the last oil because of wife's surgeries last year we did not use it a lot. I know, that is not many miles but I was just doing what I always do so I changed it.
  • I do mine once a year when I have the state inspection done. If the mileage is high, like on a coast to coast trip, I will have the oil changed when the right mileage is reached. It's been a long time since I put that many miles on the MH.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Change it being careful to put it in a clean container so I can recycle it for you into one of my vehicles. :B
    OH, never mind, I see you are in CO. No need to change it.
    -Michael
  • I consider the time period recommendations (variously 3 months, 6 months, annually) to be for vehicles that are driven regularly, but not very far. A lot of short trips will be harder on the oil than mileage built up with long trips.
    Thus if I put a vehicle into storage for two years after an oil change, I will not be taking it out every six months for another oil change. The oil, nor addititives, will not deteriorate in storage conditions.
    With today's 5000 mile interval recommendations (Ford's schedule for Ford spec semisynthetic), I would not worry too much about what happens to the oil on a long trip. If a change enroute at about 5000 miles is convenient, I would do it. If the trip is going to take me just over 5000, or maybe even 6000 or so, I'll let it wait until I get back. There is a lot of margin in that oil life estimate.
    FWIW, the oil life estimator on my 2012 Honda Fit will push the change notification out to 8000-9000 miles when I was using the car mostly for long trips, highway driving. Honda's semisynthetic spec is the same as Ford's. Ford's calculator on my E-350 van, however, is watching the odometer, and says "oil change needed" right at 5000 miles after the reset.
    Get the oil analyzed? Maybe to track potential problems, but not to save money on oil changes. My Ford dealer does an oil and filter change on my van for $10, the motorhome for $20, and I can get a $20 oil and filter change from Honda for the Fit. An analysis costs more than that. The oil costs more than that.
    However, if you are worried about it, get the oil and filter changed before you go, or do it yourself. Even if your costs aren't as low as mine, usually going in before a trip it gets your tires, driveline, belts, hoses, and all fluid levels inspected. They do this with the hope of selling you something. My dealer even does a quick battery test when he does a $10 oil change.
  • DrewE's avatar
    DrewE
    Explorer III
    Typically I think most manufacturers suggest x miles (or by a computer that monitors engine operating conditions) or once per year, whichever comes first. At any rate, five months and 1000 miles does not indicate the need of an oil change. If your trip is very long, it may be due sometime during the trip.
  • As long as you put it away hot just change by miles only. Certainly not more than once a year.
    Worst case get the oil analyzed.
  • I would get it changed while on the trip. Maybe in a thousand or so miles
