TWZMYJP's avatar
TWZMYJP
Low Point Drains
This is going to sound like a silly question, but I am clearly missing something on our new coach... The low point drain(s) do not fully empty the fresh water tank?? How am I supposed to get all of the water out for winterization and freeze protection? Unfortunately the water pump suction port is too high, and leaves at least 2" of water in the tank as well so that's not an option either...
  • You should have a fresh water tank drain somewhere under the rig. Look for a small pipe hanging down with either a valve on it or a cap on the end of it.
    And simply opening the low point drains is not likely to drain all the water from all your water lines.
