I have a 2003 DS 50amp It is currently plugged in to my 30amp server at my house. Im using 2×25ft 50amp cords.At first it's show 111volt turn on the A/c it drops 108 or so. What could be causing this...
if it drops below 108v i'd disconnect before damage is done. but what's a 'DS' and what is a 30-amp "server"? do you mean a 30-amp outlet at a campsite? but the first response is likely correct...voltage drop through the cords. did you measure the voltage at the post?
