I have a 2003 DS 50amp It is currently plugged in to my 30amp server at my house. Im using 2×25ft 50amp cords.At first it's show 111volt turn on the A/c it drops 108 or so. What could be causing this...
I am curious if you know what size wiring is running to the house 30 amp plug. If it's too small, any load on the line is going to drop the voltage quickly. If you find you do need to upgrade the wiring to that 30 amp plug, consider upgrading the plug to 50 amp with the required larger wiring.
