Jamboree89
May 29, 2017Explorer
It is possible you could have a failed battery isolator. Do you have a Cole-Hersee battery isolator? If so, try a jumper between either battery stud and the alternator stud with the engine running, this will provide field voltage to the alternator. If you get around 13.7 VDC you'll know the isolator is bad.
38,766 PostsLatest Activity: Jan 10, 2026
