dougrainer
May 30, 2017Nomad
Take a toothpick and jump the Battery Boost switch to stay ON all the time. Your system, once the chassis voltage drops below 13.1 volts and lower, the Intellitech system kicks out the charge relay that combines both chassis and coach banks. Once that happens, the chassis engine/genset and dash appliances will quickly drain the chassis and the engine and genset will die. By jumping the battery boost, that allows the Inverter/Charger to charge BOTH Chassis and Coach and not have to worry about the chassis draining down or the Intellitec charge system from kicking out from low voltage. Doug
38,766 PostsLatest Activity: Jan 10, 2026
