45Ricochet wrote:
Good luck with your sensor issue. Consider yourself somewhat lucky though in being able to get to some of these items. I see nothing but radiator :E
Have you checked over on the Tiffin site?
I do appreciate having a side radiator so I can get to everything from the rear of MH. I did check on the IRV2 forum. That is where I learned that several people have spent a lot of money and not cured this problem.
When I get to warmer weather in about a week I am going to look for the Freightliner ECM. The Cummins ECM showed no codes.
Thanks to the poster that identified which pins on the connector powered the coolant sensor.
