supercub wrote:
I just purchased this motorhome (used 07) this is my first time camping in it. I have low water pressure, both hooked up to city water and using the onboard tank with pump. Hookup has good water pressure. Could a dirty water filter cause low pressure? Any other ideas, beside a possible kink in a water line? Thanks
Brian
Brian- Check your water faucet I just went up to MN and I had no water pressure what so ever. I decide to check the water faucet and I Il be a monkey's uncle I did not had the water supply valve completely open.:o
