Deano56
Aug 29, 2015Explorer II
LP Fill Fail
I went to Menards tonight after we filled the tank with gas, so that I could get a fill on LP. The girl screwed the nozzle on the fill port and pulled the trigger, gas shot out the vent, so she tried ...
dougrainer wrote:Vapor came out, she said it was the bleeder valve, she said even when she closed it all the way.just to show me, but I don't know that for sure because I backed off when she pulled the trigger. All I saw was a big puff of vapor. I did close it tight my self just to see and still big puff of vapor. I'm going back there this afternoon to see if I can get someone else there to try, other wise I will have to wait till next Friday when I'm off work to get to another placeDeano56 wrote:
let me spell this out more clearly, the vent did not fall off, it was/is there in tact. She did turn it open a little to see if there was any gas in there which there was not, then she pulled the handle and propane shot out, but I could not see from where as I backed away. Maybe the gasket was missing on the nozzle, or like some said the bleeder valve is bad. I'm going to take it apart
You state LP came OUT. You mean LIQUID came out or LP VAPOR came out? Out of the 80% valve(bleeder) or the fill nozzle area? If the fill nozzle area, then the gasket was missing or not seated. If LIQUID came out of the Bleeder, the tank was FULL. If Vapor came out the Bleeder, that is normal. Regardless, the person filling your LP tank is NOT qualified and should NOT be filling LP tanks, PERIOD. I will assume in your State, there are no regulations that govern LP operations. Doug
