Deano56
Aug 29, 2015Explorer II
LP Fill Fail
I went to Menards tonight after we filled the tank with gas, so that I could get a fill on LP. The girl screwed the nozzle on the fill port and pulled the trigger, gas shot out the vent, so she tried ...
msmith1199 wrote:
Vapor is supposed to come out. You can't fill a pressurized tank with a liquid gas without giving the air someplace to go and it goes out that valve. That bleeder valve gets opened and as you fill the tank you can hear the hiss from the vapor (air with a propane smell to it) coming out of that valve. When the first sign of liquid appears then the tank is full. That's why you don't smoke while filling the tank with propane. Everything sounds perfectly normal to me.
