inky's avatar
inky
LP Refill Locations
Is there such a thing as an app, list or website I can use to find a place to get my class A LP tank filed while on the road? I know some Flying J's have LP available that I can get my tank filled, but not always around Flying J's. I have a large tank not the 20 or 30 lb cylinders.
Thanks,
  • http://www.allstays.com camp ground app has propane including truck stops. I have found that Uhaul has access and usually a good price.
  • wny_pat wrote:
    Google works.
    X2
    The DW googles "Truck Stops with propane" & they pop up.
    Works great. Plus you know you have room for the big rig. :B
  • I've not found an app or website that lists all LPG retailers let alone distinguishes them as to whether a large RV can get to the pump as a pull through, or do so without backing up. Most lists are "there is a dealer at this location" which may or may not work fir you.
    A big issue whether the retailer is conveniently open, as many keep their service people on the road, and you may need to call for an appointment to meet at the pump. Probably 2/3 of the LPG bulk dealers in my part of the country are unmanned at storage and pumping locations, and smaller 2nd or 3rd tier retailers often don't have room around their pumps, or need a RV to back in or back out.
    The most convenient locations I've found. have been at RV parks. Because they service RVs they are set up to be convenient for drive through, and are usually happy to sell you LPG if you are on the way in to stay for the night.
  • U-Haul (full service) stores. Most Tractor Supply stores. Don't know of an app, but will watch this thread for that possibility.
