werni9ExplorerFeb 25, 2015LP tank serviceI have a Brunner MFG. 40 lb. LP tank that has a stuck filler valve. Manchester Tank Co. bought out Brunner in 2000. I have a 1/2 tank for the next 5 days of near freezing temps. Anyone have a similar ...Show More
wa8yxmExplorer IIIFeb 25, 2015Meanwhile. IF you have not already done it...A Extend-A-Stay or Stay-A-While (Extend-a-stay was the name back when Marshall Brass Made it, Stay-A-While is by Mr, heater, appears identical).Put it between your tank valve's POL fitting and your regulator.. And you can feed in propane from an external tank when you need to.Works good too.
