Georgia_CrackerExplorerNov 09, 2013Lube pump kit for 4 downIt's time to replace my tow vehicle. The vehicle I want requires a lube pump. What are the pros and cons on using a lube pump, also what can I expect it to cost?
Carvin_MarvinExplorerNov 10, 2013Call Remco they will give you the cost. They are usually at the big tent in Quartzsite in January if you are here then.
Related ContentWater PumpLube pumps for towingRemco transmission lube pumpTransmission lube pumpLube pump
