Lost_Motion
Nov 11, 2013Explorer
I installed a Remco lube pump on my '96 Dodge Caravan. Takes longer than the estimated install time. A piece of cake!! It's time consuming, but us retirees usually have plenty of that. The most time consuming part is checking to make sure that the correct output from the tranny goes to the input of the cooler on your radiator (checked mine about 2K times). Also, there is a set of wires that have to be threaded inside split plastic tubing for the length of the MH. These wires go from a pressure switch on the pump to a indicator light on the dash of the MH. Switch on: Green light = pump running. Red light = pump not running. Total cost approx. $900.00 (Kit only). Key words....double, triple, quadruple check your work and plan ahead. Everything works great.
Ed
Ed
38,766 PostsLatest Activity: Jan 10, 2026
