prism wrote:
rsilvestrone wrote:
Thanks everyone for input, got some heavy duty scrap wood from homebuilders around here & drove rear wheels up on blocks, had plenty of room then to wiggle around,Othertonka sorry not the wheel bearings its the grease fittings, located on axles, & driveshaft. they can be greased with grease gun & #2 heavy duty chassis grease ( at any auto store) thanks all, Robert Bozeman, Mt
the grease fittings are not the axle per say.There the brake cams and the slack ajusters plus ujoints and the slip yoke.I have a 2008 Bus and there is plenty of room to lay on the ground with a tarp
Actually I just did it a few days ago.One can put the jacks down on spacers and lift it up a few inches if your personally a little on the big side
That will work fine as long as there is no suspension failure. Don't like trusting my life to air bags, air lines, ride height valves, etc.
But, just going up on blocks 4-6" not only insures more working room, but room to live if there is a failure.
Yes, some coaches have enough room for some size guys even with the suspension collapsed-- check yours before going under there.
