othertonka
Nov 17, 2013Explorer
drakethib wrote:
Would anyone know what size lugnut fits a 2006 Fleetwood Bounder Wh Chasis?, Tire size 22.5?
Had new tires put on and one is missing, calling to call the tire shop but just in case I need to buy one.
Thanks!
Take it back and make them replace it and have them use a torque wrench and torque them to 450 ft lbs. You probably do not own a torque wrench that goes that high. the right wrench will be about 4 foot long. Also the proper lug nut will be a "Hub piloted" nut with a washer attached to the nut. Put 2 drops of motor oil on the nut between the nut and the washer before installing the nut. Don't take a chance without the proper torque. To do it by yourself you would need a cheater bar about 4 feet long and put at least 110 pounds of force on the end to get 440 ft lbs of torque. This is just my suggestion
38,766 PostsLatest Activity: Jan 10, 2026
