wolfe10
Dec 04, 2016Explorer
Not familiar with the 1220 Kisae Pure Sine inverter, but a quick glance at the specs does not suggest there is any 120 VAC INPUT or ATS.
So, initial assumption is that this inverter powers the refrigerator 24/7 and that your on-board converter or charger recharges the batteries from shore power or generator.
Is that how it works-- that the refrigerator is plugged directly into your Kisae inverter and that the inverter has no 120 VAC in from your coach 120 VAC breaker panel.
If this is so, no problem as long as you do not let battery voltage run too low before recharging.
38,782 PostsLatest Activity: Sep 10, 2026
