Mile_High
Dec 04, 2016Explorer
The manual also says:
"In moving vehicle. This unit is not designed to be installed in an RV or used with an inverter. This unit is intended for household use only."
So if you already broke rule number one, rule number 2 won't matter much :)
However, that may not be enough inverter to do the fridge and the other things you have on it.
38,782 PostsLatest Activity: Sep 10, 2026
