Bill_Satellite
Dec 04, 2016Explorer II
The Kisae 1220 is an PSW Inverter only. It's 2000W so it is more than enough to power the fridge and the other entertainment components mentioned.
Input: 12 VDC
Output voltage: 120 VAC, 60 Hz
Continuous Power: 2000 W (16.6 A)
Surge Power: 4000 W (33.3 A)
Output waveform: Pure sine wave
Dimensions: 9.5 x 16.5 x 4.5 in (240 x 420 x 115 mm)
Inverter weight: 12.0 lbs (5.5 Kg)
I have a Kisae brand inverter/charger and it is a very good and dependable product.
It appears someone set this up with dedicated circuits for the items listed above. If that's true Roachcoach, then this item would not work if you turn off the inverter and have the coach plugged into shore power or you are running the generator. Is that the way it is setup?
Input: 12 VDC
38,782 PostsLatest Activity: Sep 10, 2026
