Just replaced inverter because i kept getting a fault light when i tried to use it. Now i keep getting a batt. Low red light. Batteries are less than 1 year old. Any ideas??
Did you check the voltage on each battery? Does yours take water and are they topped off? Do you have the controller set to properly charge the batteries? Do you have the cutoff switch on? Are the battery connections tight and clean?
