Booner's avatar
Booner
Maintaining air pressure in your tires
I've had my RV for less than a year and I'm religious in checking it's tire pressure. I had an inside rear dual that always seemed to loose a little tire pressure, so I checked pressure often. I thought I may have to take this tire to a shop to have it remounted.
I went to an auto parts store and purchased a little screw driver looking thing that is used for inserting the tire valve into it's stem. (I'm sorry I don't remember what it's called). Like I said, the tool looks like a small screw driver with a slot cut into it's stem. The valve fits into this slot and allows you to screw the valve into the tire valve stem. It costs a few bucks.
I fit this little tool into the valve stem on my leaky tire and found that the reason I was loosing air was the valve was a little loose in the stem which allowed a bit of air to leak around the threads that holds the valve within the stem. It took almost a full rotation of the tool in the tire stem before the valve was firmly seated in the stem.
I tightened all of valves on all of my tires and they all have held their air pressure since I did this. For a few dollars this little tool gives me some peace of mind.
I just looked it up and the tool is called "a GVX Valve Core Removal Tool" - under $7 on Amazon. I purchased mine at a local car parts store.
and a link--> https://www.amazon.com/GVX-Valve-Core-Removal-Tool/dp/B01IE7EL1E/ref=sr_1_5?dchild=1&keywords=Schrader+Valve+Tool&qid=1624644307&sr=8-5
