GrumpyandGrandm
Dec 18, 2013Explorer
oilslick wrote:
I say use the PEX with the solid crimp fittings, it's just too easy to use and will withstand whatever you throw at it. Need to go round a corner use a 90 deg fitting. Also use the correct cutter you'll thank yourself later.
I'd skip the PEX and use Shark Bite fittings. No special tools needed, just push the tubing in and move on.
