Guardpasser5000
Jul 19, 2021Explorer
jrloucks wrote:DrewE wrote:
If you need chassis information, that should be available from Ford or the usual other companies (Chiltons, Haynes, etc.). Since the E series vans were very popular, there are also lots of YouTube videos, forum posts, and so forth online about most any chassis maintenance thing you'd run into that can be found with a bit of searching.
Finding service documentation on individual appliances and other third-party bits is often not too hard once you get the maker, model number, etc. from the thing in question.
We have a 1984 Travelaire and this is exactly what I ended up doing. (a) Purchasing a Haynes Manual for the Ford Chassis, and (b) searching on-line for copies of all the OEM appliances installed by the RV manufacturer (fridge, stove, hot water heater, furnace, etc.)
The ford truck enthusiast forum at https://www.ford-trucks.com/ is also a very useful source for information/help.
Your Travelaire should have a large manufacturer's label stuck somewhere. Our label is stuck on the inside of the bathroom closet door. This label includes details about where the RV was built and all the model numbers of the OEM appliances installed at the factory.
I found that this weekend. Thankfully I also found a shop here that deals with this chassis and manufacturer quite often as it is. Thanks again everyone.
38,781 PostsLatest Activity: Aug 12, 2026
