First step is I will "dry fit" the master cylinder so that I can make the two brake lines between it and the distribution block assembly.
Then I will bench bleed the master cylinder and connect it to the new lines.
Then I will power bleed all the brakes starting with the passenger side rear and finishing with the driver's side front.
I think that I will have completed the brake rebuild and will have to take it out for a road test...not too far from home however.
Thanks to all of you for your responses.
