msmith1199 wrote:
GCWR is the Gross Combined Vehicle Weight Rating. That is the max gross of the motorhome and the toad. GVWR is the Gross Vehicle Weight Rating. That's the max weight of the motorhome alone. Neither of these numbers gives you the cargo weight capacity as you have to know how much the motorhome actually weighs first. These are max numbers, not the actual weight of the motorhome.
Thanks! That helps. After two days looking at RVs and going to seminars my head is spinning. Now that I think about it again your answer is obvious.
