msmith1199 wrote:
I don't see on Winnebago's webpage where they list an empty weight of the RV. I don't recall seeing that number on any motorhome as they are probably variable. There is a lot of wood in a motorhome so identical motorhomes could have different weights. I have never weighed mine, but it's probably a good idea to do so. And just because the GVWR is 27,910, doesn't mean the axles are going to fall off if you load a thousand pounds or so over that.
Some manufactures list approximate unloaded weights in their spec sheets (Winne does not)to give you some idea on what you can carry. However they are required to have the finished weight as manufactured posted on the motor home.
