Cu2
Jan 10, 2013Explorer
Now dreading the next bit, which I'd been procrastinating to do. The first hole in the body work.
Dad was discouraging - get a pro to do it. He ran away before I started couldn't watch.
Well I'd spent 1 full day making sure the hole would be correctly positioned.
It could only fit if the WC was raised. Hence the raised surface of the Shower base.
So here we go, no turning back now as I attempt to drill the first guide hole the bit kept on sliding away. Ok so I went inside and drilled from there easy. Went to check outside ..... WHAT THE !!! It's in the middle SH.....T I need the panel for the door and now it will have a hole in it.
240V wires showing.
Not bad - used a jigsaw for that. It jumped around too much horrid. Damaged the masking tape and nearly the enamel. Sanded back and make edges smooth then rust proofing the edges of bare metal.
Here using the cut out to put in the door frame.
Few I was lucky enough that the hole was covered up by the shape of the frames corner.
240V wires showing.
