Cu2
Mar 03, 2013Explorer
Compliance plate for GAS no fridge!
New Mircowave and the New fridge - Had to line all walls and the back but used vents for air circulation as the space required was not sufficiant on it's own. Now have to secure it but needs to be moved for cleaning at the same time.
The fridge is a 12V fridge 158 ltrs runs at 4.5 amps. Also with a transformer 240 V running at 1.08 amps. Must change plugs over no switch so a bit inconvenient to boot.
Wont be able to run it any length of time with out hooking up to house hold power source. Solar panels also wont cut it. - I would need 2 solar panels and 3 x 260 amp hour batteries so I am told to run. All too much weight and money. So looking into using "Dry ice packs" Anyone else use them? What ever I am now limited as to where I stay over night. Very sad indeed.
