Cu2
May 29, 2013Explorer
Moving on in the windows finishing stages.
Inner lining back in, now its just a matter of making a nice edging / sill.
After I ordered the window I was regretting having ordered rounded edges. Making it so much more difficult to finish the inside off, oh my oh my.
The challenge was getting the rounded corners right, which took its toll, once the inner wall was in I found out that nothing much ran level to the frame of window with corners and sides and the top. I did how ever get it right on the bottom. Right so here I go with so much as a file, chisel & hammer all hard work but not getting anywhere fast, lastly I used a dremil with the little sander which shaped the corners well.
But I'd had enough. Stuff, it will have to do.
On with the laminate.
First part on, the photo showing construction to keep the pressure on as I used sikaflex which takes a few hour to cure. Ok yes it looks a mess here, but I am not finished yet.
Opened
In the meantime I adjusted the gas struts to get the angle right, so it doesnt rain in when opened.
Closed.
Opened
Closed.
