The 600 may or may not be out of line depending if the Toyota will need to have things moved around to fit. Call M&G they will know.
On my jeep it took about an hour to install the air cylinder to the vehicle I had new brake lines manufactured at a brake shop because they where to short that added about 30 to 45 minutes. I also needed to move a bracket that held a air pollution sensor and that added maybe 30 minutes more so I am at about 2 to 2 and a half hours.
I had a mechanic that worked on air brakes do the MH that took about 30 minutes.
JimR
