Crespro wrote:
x2 M&G is very solid and simple to connect the toad.
...One thing to keep in mind with M&G: It is incompatible with a lot of vehicles.
I believe this is partly because it mounts onto the brake master cylinder, makes the master cylinder protrude further out by a few inches as a result. If there isn't enough clearance for the master cylinder to protrude out a few more inches, M&G will not work. There's probably other more technical reasons why M&G is incompatible in many cases, but its definitely something you need to check into and research before plunking down the $$ on an expensive system like that.
With how tight I've seen things are under the hood with many newer vehicles, I'm amazed M&G can work with ANY modern vehicle, haha. :)
