j-d
Jan 01, 2016Explorer II
That 223" number is my first piece of good RV news in 2016! That should put good weight on your front end and keep the rear out of overload.
Our 31-ft has 218-in WB with weights 4600 Front (65-PSI) and 9250 Rear (75-PSI).
Till you get actual weights, my pressure suggestions for you are:
FRONT: 70-75 PSI
REAR: 75-80 PSI
Those get you right to the max axle ratings. Notice that the tire is rated to carry a little more in Single than in Dual.
Do not run the Front at any more pressure than weight calls for. The contact patch with the road gets smaller with excess pressure and that compromises tracking on the road.
FRONT: 70-75 PSI
REAR: 75-80 PSI
38,782 PostsLatest Activity: Sep 10, 2026
