ander's avatar
ander
microlite 2800 blowing white smoke
hi all
the onan 2800 in my 94 pleasureway has started blowing white smoke.
i havent used it much over the past year..and i will admit i havent exercized it enough...maybe 30 mins every other month.
it runs great except for the sudden smoke. unit is very clean inside with no sign of leaks.
pulled the plug and was soaked in gas.replaced with new one and smoke started up again a few minutes later.
its sounding like a carb issue?
ive heard these arent rebuildable but has anyone had this issue?
thanks
andy
  • If it was over rich it would seem to be black sooty smoke. If it's more white it would seem like coolant if it was water cooled. Burning oil may seem whiteish but is usually more blueish. Check for over filled oil then also look for oil in the breather /intake side of things. It could be rich so check that then perhaps move on to a quick compression test. A more through test will be a leak down test that will give you an idea of percentage of wear on the combustion system. A leak down test will tell more than a compression test.
    If you ticked someone off they may have pumped your muffler full of grease and it will smoke for hours. :) Oh yes it will........
