Escapade wrote:
I have used this 50amp plug on our house since 2011 with no problems. I did run extension cord to the tv and micro from the house and they do not work. Some how I got a surge that took out these.
They do make inexpensive meters/test plugs that can be used to check your outlets throughout the coach to see if you have any ongoing problems. These are available at Home Depot or Lowes. I like to use this type to check voltage, current usage, frequency(when using generator), and the amount of power an appliance uses.
Kill-A-Watt
